Old 09-15-2010, 11:42 AM   #181
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Angry Re: Drag Pak/Cobra Jet FX classes
There is a lot more in the CJ's that makes them fast than the supercharger.
That "Magic Fairy" has been bolted not only in the CJ's, but also in a lot of other of other OEM cars including Japanese, European and US cars, including GM.
For starters, you have a OHC engine with very efficient cylinder heads. Then add what is called in the automotive industry, Displacement on Demand (DoD) Systems.
The DoD technology enables the Engine Control Module (ECM) uses the information related to the operational status of the engine to implement real-time running efficiency of the engine and effects changes in the operation of the engine through the control systems that manage its operation.
I do not know if the these cars are using Variable Cam Timing (VCT) and/or Variable Valve Timing (VVT) like the new Ford 5.0 engine does. I have seen the ECM graphical displays for VCT and VVT and I can tell you you can program the cam events for maximum engine efficiency throughout the whole run.
If the next generation of CJ's have the new 5.0 engine, as proposed, with ECM controlled VCT and VVT, watch out.
More reasons to put them in their own class OR add a ton of HP to the factor.
Old 09-15-2010, 11:43 AM   #182
GUMP
Liked 2,359 Times in 557 Posts
Default Re: Drag Pak/Cobra Jet FX classes
You are old enough to remember when they had to run the factory exhaust!
Old 09-15-2010, 11:50 AM   #183
X-TECH MAN
Banned
Talking Re: Drag Pak/Cobra Jet FX classes
OUCH ! but yes I do.
Old 09-15-2010, 12:09 PM   #184
Chad Rhodes
I beg to differ. A naturally aspirate mod motor from ford (aside from the new 5.0) is best suited for use as a boat anchor. They are bloated, oversize, overweight (as big as a hemi), and don't run worth a crap without forced induction. Why do you think the "crate" CJ's are windsor base?
You are correct about the VVT/VCT, although DOD will have no affect on a race motor. If they are allowed to run VVT/VCT it will open a bigger can of worms than EFI did when it first came on the scene.
Chad Rhodes 2113 I/SA
Old 09-15-2010, 01:03 PM   #185
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Terry you old fart ! Yea but they were not hooked to the hedders, they just hung there.
Bob Pagano A/SA
Old 09-15-2010, 01:45 PM   #186
Bruce Noland
Liked 444 Times in 145 Posts
Originally Posted by Sean Cour View Post
What? You actually have to work on these Devils in a white dress? Spend some money on them? I thought you open the box at Christmas and BAM! You're 1.75 under. Hmmmm.....I guess Big Daddy didn't get the TSB when he received his crate for Christmas.
Work? Who said work? Money buys the action with these new cars.
Just wait until real Stocker racers spend some serious time with them. Got to be another .020 -.030 in them. I guess you have been slaving away on the new CJ. lol Gracie rolled her CJ off the trailer and popped out some 9.60's. BTW, who helped Gracie and Bill during tear down at Indy? That had to be a serious project.
Bruce Noland 1788 STK
Old 09-15-2010, 02:18 PM   #187
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
Gracie and Bill had a crew member helping and some of the other CJ racers pitched in to help them. I also saw one of the CJ racers helping a drag pak car in tear down. Some CJ racers were ready for tear down long before they actually had to go to the barn because they new they would eventually get an invitation.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 09-15-2010, 04:42 PM   #188
Bruce Noland
I saw the car in tear down but wondered how in the world they would be able to do it on their own. Glad they got help.
Old 09-15-2010, 05:49 PM   #189
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
What's a "real Stocker racer" Bruce? Someone who strokes a keyboard to improve the ol' combo? I don't know about you, but we've been actually trying to improve the CJ. Trying to make it a race car, not a collector car.
Better mousetrap......kinda like a two barrel!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 09-15-2010, 06:06 PM   #190
RULER
Liked 58 Times in 18 Posts
Sean, why in the world would you need to work on making it faster, you have everybody covered by 3 to 5 tenths now. Do you need to cover them by 8 tenths or what, plus somebody asked a question earlier about what type and how many parts you test on your new car before you found the right combo that made it so fast. You don't have to tell everybody sizes or ratios just how many things did you have to do?
RULER is offline   Reply With Quote
