Old 09-12-2010, 02:30 PM   #15
Dgal
Default Re: Question to Ford, CJ Owners and supporters
Sean, how much do you think it will cost building a competitive AA, A, B or C Stocker that is not a CJ or DP?
A competitive car for the higher classes, built from scratch in today's dollars, can cost almost as much as a CJ or DP by the time you are done with building the car and doing all the R&D.
The problem is that it is not competitive against a Cobra Jet or Drag Pak even if you spent twice the amount. The Cobra Jets and Drag Paks start out with significant advantages that any other combination cannot overcome without larger runner volumes, larger throttle bodies, larger valves, greater lobe lift, and or power adders. Plus the deep pocket R&D of the manufacturer.
Dgal is offline   Reply With Quote
