Old 09-07-2010, 06:40 PM   #1
Liked 10,721 Times in 2,232 Posts
Default Re: INDY - the highs and lows
Kelly,
So sorry you and your wife got sick. I wondered what had happened to you, since you were not there for qualifying on Wed. Hopefully you both are feeling better now and will come back again sometime.
Patsy
Old 09-08-2010, 05:17 PM   #2
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
High: Getting the A motor together and getting to Indy.
Low: Wensday 1st pass car doesn't run what it should.Thursday 2nd pass car slows even more.
Low: Take oil filter apart and it's full of bearing material.
Low: Thursday @ 2:30 Drive 1.5 hours home pull motor and tranny,take carb,intake,heads, cam & lifters,timing chain, oil pan & pump, and put on spare short block, put spare motor and tranny back in car,sleep 50 minutes and drive back to Indy for class Friday Morning.
High: WIN CLASS.
Low: After .007 light in 2nd round, give the stripe back to Lincoln Morehead by.007
Low: Not getting around to visit like normal.
Indy has plenty of high's and low's,wouldn't miss it for the world.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
