Old 08-13-2010, 05:41 PM   #15
FINESPLINE
FINESPLINE's Avatar
Default Re: 69 camaro value?
As far as looking for an early Camaro , E Bay and Cars-on-line will give you an idea of what is out there. If you are looking at a real COPO 9561 car (steel head 427 ) be prepared to talk to your accountant. I have been to a lot of shows and have seen some fantastic recreations of of these cars --right down to the correct block and head casting , carb numbers, trans and rearend code numbers. A COPO car recreation pops up every so often on EBAY. The more correct the the more the money. Prices are also vary with the season. e.g---going into fall & winter prices will be more negotiable and in the spring the number will be higher. Spend some time to learn as much as you can about what you want and it will be a much more enjoyable experience.-----John
FINESPLINE is offline   Reply With Quote
