Old 07-30-2010, 08:44 AM   #81
Dan Fletcher
Sponsor
Dan Fletcher's Avatar
Liked 1,045 Times in 70 Posts
Talking Re: A case for aftermarket seats in stock
When time permits, I'm definitely going to look into locking my seat in place, ie: taking the slide track function out. I rolled up to the lanes for round # whatever at Chicago earlier this year and got out of the car. When I went back by the driver's door, I noticed that the seat was significantly closer to the steering wheel than it was when I got out. A piece that locks the track in a given position had broken and the seat was free to just flop back and forth, although the springs kept it biased forwards.
I was able to make the run, as I'm tall and push the seat all the way back. Had a shorter, un-named friend of mine been driving, we would have had a problem...LOL...
Dan Fletcher 1781 STK, SS, COMP, SG, SC
DAN FLETCHER TRAILER SALES
Dan Fletcher is offline   Reply With Quote
Old 07-30-2010, 10:32 AM   #82
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Re: A case for aftermarket seats in stock
Originally Posted by Chad Rhodes View Post
just as a rebuttal to the weight issue and the huge advantage it is; I just weighed our new 92 camaro H-I-J/SA car. Its no lightweight, heavier centerline wheels, stock brakes, nothing cut up or acid dipped, mild steel bar, stock POWER seats, etc. as it sits with me in it its 50 lbs light for H/SA, the lightest class it can run......................and I'm 245lbs. i don't see the whole weight issue. aftermarket seats would have just added to the massive amount of weight the car nees
Chad,
Do the shipping weights for these new cars include the discarded A/C units and cruise control, etc.? (I bet the 69-71 ish weights are for a stripped down car.)
What NHRA did not do was reflect the weight reduction of items such as aluminum brakes and things. The easiest way to eliminate the seat weight advantage is going back to every car must be nose heavy. (Anyone recall when that was lifted from the rule book?) It would eliminate all the trick stuff advantage. Does a guy with a 1970 six cylinder Maverick really need $3,000 of aluminum brake pieces to stop? No, but he does to run with the others in his class if they loose the weight there.
I could never understand how NHRA and IHRA let guys race without fire jackets or pants. If your V/SA car is hit by an A/S car and pinned to the wall, don't the flames burn you too while you cannot get out?
Look at some of the early Top Stock images. The A/B/C Stock Eliminator guys had jackets while the Top Stock guys had short sleeve shirts. For those of you not wearing fire resistant pants, I'm going to help at the hospital again this weekend, come along with me and see if those bozo nylon pants help you at all. We won't even get into back/neck injuries...
Old 07-31-2010, 07:32 AM   #83
Johnny Rod
Hey Dan would that little guy be SB?? LOL.
Johnny Rod is offline   Reply With Quote
Old 07-31-2010, 02:24 PM   #84
Run to Rund
Liked 54 Times in 27 Posts
Several years ago I welded tabs on the two sliding sections of each track and ran a bolt through the tabs to lock the seat. If the seat has to move, remove the bolt on each track.
Old 08-04-2010, 07:34 PM   #85
427_ED
427_ED's Avatar
Liked 2 Times in 1 Post
Arrow Re: A case for aftermarket seats in stock
If you could get a couple of seat manufacturers to $hake hand$ with the NHRA ............
427_ED is offline   Reply With Quote
Old 08-04-2010, 08:30 PM   #86
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
I've been saying it for years, But it's a sad State of affairs when someone has to get killed to change the safety rules. I know of very few racers that will complain when they update the rules to make his car safer.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 08-04-2010, 08:55 PM   #87
Liked 1,878 Times in 422 Posts
Steve, evidently you missed the guys complaining about being forced to wear real pants in Stock, as opposed to putting sweat pants or pajama pants on over shorts. Not all of them, but plenty of them. I wish it was unusual to have racers complain about safety improvements, but that has never really been the case.
Motorsports is continually in that sad state of affairs, at least half of our safety rules are written in blood, it has been that way for as long as I've been following motorsports. It is rare when it is different.
I can certainly see why people would be unhappy with the idea of ultra trick lightweight expensive aluminum fabricated seats in Stock Eliminator. Given the fact that there are a lot of truly purpose built race cars in Stock that can add or remove enough weight to legally run three classes I'm not sure I buy the issue about being able to move weight. However, those sheet metal seats do look very out of place in a Stock Eliminator car.
There is probably a way to reach a "happy medium", with something like a fully upholstered and cushioned aftermarket racing seat with an actual frame and springs, as opposed to the sheet metal fabricated seats with a layer of material on them.
Old 08-04-2010, 09:52 PM   #88
treessavoy
Liked 4 Times in 4 Posts
The progression of safety issues in Stock and SS have, as Alan said, have come via blood, major incident or by stubborn individuals like Bob Mazzolini who put a dual master cylinder in his Max Wedge car and dared them to say anything.
How stock is stock? Will the NHRA let me do away with the required bench seat in my '64 Plymouth for non-stock bucket seats. Will the NHRA make a deal with a seat maker and therefore control the price of the seats. I know some of you will ask me how much I'm willing to spend to possibly save my life but I can't spend $2,500.00 for a pair of seats at this point.
Does the spectator (those few that watch) care about what seats are in Stockers? What performance advantage do safer seats give me?
Lastly, is this really a problem that needs to be addressed or (as usual) are we beating a dead horse here?
JimR
Jim Rountree
Old 08-05-2010, 09:10 AM   #89
Mickey Whaley
Like i said before if they pass the rule to allow a racing seat let it be up to the driver if he or she wants one then everybody can be happy.
Mickey Whaley is offline   Reply With Quote
Old 08-05-2010, 09:40 AM   #90
Greg Hill
Liked 279 Times in 68 Posts
JimR
Jim, look at my initial post. The seats I bought for my son's car looked a lot like stock seats cost around $220 each and were much better made than the old stock seats. For me to find a pair of 1970 Camaro seats, buy new foam, new springs, new covers and pay someone to upholster them would be around $1500. I would not favor allowing racing seats like the Kirkeys because they look nothing like stock seats. The procar seats I bought have tubular steel frames with steel springs and two locks on the sliders. The seat backs lock much more securely than any of the old stock seats.
Greg Hill 4171 STK
