Old 07-16-2010, 07:28 AM   #1
Tweaker
Tweaker's Avatar
Default Re: Dragster maintenance
What would you say give or take is the average price if you took the motor somewhere to get freshened after the 150 passes or so etc.
And what about other parts like the Transmission? How often do you need to service etc? Etc.
C & W Racing, That is cool. Do you ever come down to Palm Beach International Raceway? Or ever plan on it? if so let me know I can come out and watch & learn from you. That is really cool but I seriously doubt though I can afford a 2008 Year Chassis with a 4 link. I would not be running Super Comp but local brackets in the Box class in the beginning years.
IHRA #2X41
http://khracing.projectrhyme.com
Tweaker is offline   Reply With Quote
Old 07-16-2010, 08:25 AM   #2
Bill Baer
If you stay on top of it you can get 250-300 passes I can't give you a accurate estimate on a complete motor freshen up as I do most of the labor myself but your probably looking at 3K in parts and 3-4 K in labor.
The other stuff:
The transmission I also disassemble every winter but, it usually is in good condition I would recommend you have yours inspected annually.
The torque converter is one item I can't and don't maintain myself I run them to failure or sell them after a couple of years. I know this is not what the Converter builders recommend but spending $300 to have a guy cut your converter open and tell you it's Ok and weld it back together every year or two just doesn't make sense to me because after it's opened and closed it still has the same number of fatigue cycles on the sprag, metal fins and the braze joints and there is a chance that if the clearances have been altered it may work differently.
The brakes I rebuild the calipers and reline them and change the fluid annually.
The ring and pinion I run to failure, the orginal set had more that 300 passes on it and the wear pattern looks fine.(I do flush and change the lube annually)
The slicks will go 150-200 passes (although most people change them every year.)
Old 07-16-2010, 10:27 AM   #3
Chris Williams
Chris Williams's Avatar
For us:
- Motor: really depends on what they find. This past winter was an easy one, the bill was under $2k. Previous year it was almost $10k, but we also added the better part of 100hp doing it.
- Tranny: got tired of being nervous so I bought a complete spare setup (tranny and converter) this winter. Ouch... the better part of $5k. But I too run converters until there is a problem. Can be several years. Tranny, I have my guy look at it when I suspect a problem. New pump $450, new clutches and bands, something similar.
- Rear end: change the fluid every year, running till it dies, we're at well over 300 passes, got a long way to go.
- Brakes: inspect them every 20 or so passes, have a spare set of pads in the trailer to pop in when needed. That can be 200, 300 passes. Just top off the fluid once year.
- Tires: I think 100 is plenty on a set, but I know people who agree that you can get somewhere close to 200. They go until their 60's start to go away. Since I can't store my car in a heated space up off the concrete (lives in my trailer all winter), I buy a new set of slicks every spring, a new set of fronts every other. Slicks: $650, fronts: $350.
- Fluids: keep a lot around. Change oil and filter every 20-25 passes: 6 qts + filter. Tranny, drain and refill a lot it seems: ~7 qts. Rear ends: ~2-3 qts. Fuel: use about a drum and a half every year, ~$1500. Lucas Oil Slick Mist polish: about 3 bottles a year
Single biggest expense to drag racing: diesel fuel for the truck. Probably spend the better part of $6k a year on that.
HTH,
Chris
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 07-16-2010, 11:04 AM   #4
Tweaker
Tweaker's Avatar
Thanks a lot for the information I will document this for myself for the future.
Since I have a lot of great guys providing information I have also started a list of what to look for when buying a used turn key RED. If you guys could provide any helpful tips or information to ensure I don't get ripped off when the day comes when i pick up a Used TK RED.
IHRA #2X41
Old 07-16-2010, 01:52 PM   #5
Bill Baer
Well I'll start:
Chassis tag it must have a current chassis tag
Do not buy a mild steel car almost all are chrome moly but, there are a few out there that are actually mild steel (IMO they are basically junk)
Get one that fits you .
Check the SFI dates on everything (look in the back of your NHRA rule book).
Ask the guy what kind of maintenance it requires, if he says "nothing" that probably exactly what he has done.
Look for quality parts Strange , Mark Williams Aerospace Engineering ect.
Like I said earlier ask to see it make a pass.
Don't even think about a front motor car unless you want to leave it to your grandson.
Look for quality and cleanliness If the guy took good care of it and or made a low number of passes with it it's probably spotless but if he put several hundred passes on it a year and just ran the living **** out of it, it will show.
If you can take your mentor along if he has owned these type of cars before he could be you best source of information.
Be patient look at several last time I looked there are about 500 of them for sale on racing junk.com
Old 07-31-2010, 08:25 AM   #6
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Tweaker: I am just south of Tampa, Fla, and have some of the best Dragster guys around here. A good person to get a hold of when your ready would be Stanley Albritten Jr. he always knows af a car or two for sale and usually will vouch for the cars because he is the one maintaining them. Down your way there are alot of guys running PBIR on aregular basis who normally run T/D, I would check them out as well.
We just got our first Dragster, and bought it knowing it needed to be front halfed.. Otherwise the car is in great condition, just a minor bump in the nose area that caused some issues. Car is currently on our jig ready to weld back up, and hope to make the next divisional race with it.
If you need anything dont hesitate to ask, I dont mond helping out anyone either.
Freddie is offline   Reply With Quote
