Old 07-10-2010, 09:48 AM   #12
voltdr
Liked 100 Times in 51 Posts
Default Re: crew chief pro or ifamily
What I meant to say was that he uses the CCP to get an idea on what you think is happening so when he races you he can adjust how you are going to race. How much you (using CCP) will be allowing for weather changes etc. He did tell me that parts of CCP are pretty good but, other parts aren't. I use and old B&G computer, similar to the ifamily unit (I think). I use in conjunction with a spreadsheet to help me predict ET changes for the change in weather. Once I know the weather change, then I will make adjustments for track, wind etc.
voltdr is offline   Reply With Quote
