#11 | |
Dodge 370 385 390 399 2009 Challenger How do you arrive at a 9 hp increase.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#12 |
Liked 325 Times in 50 Posts
2.25% increase based on a run of 1.17 under at a national event and an average of .85 under for the engine combination with an automatic transmission at national event year-to-date, or .85 under since the hp factor was last adjusted this year.
Jeff Teuton 4022 STK |
#13 | |
Jeff Lee 7494 D/S '70 AMX |
#14 |
Ug, when it's a power increase, the '81 Camaro gets lumped in with the '82-'84. When its a reduction it gets left out. Hopefully its a typo.
#15 |
Liked 58 Times in 18 Posts
But Jeff didn't say or know is the 427/435 is also one full point of comp less and also has a smaller cam than the L88. how in the heck did somebody get HP off an L88. I see they didn't reduce the HP on the ZL1, it's still at 445 and it's the same except the cam as an L88. Well gota go now and see if putting my fingers in a wall socket will help me understand how they think?
#16 | |
#17 |
but i have an intake manifold that got ran over by a concrete truck, and a little cam, etc etc. but by NHRA's logic you're probably right
Chad Rhodes 2113 I/SA |
#18 |
So you are saying the longer you race a combination you are making less power? I don't understand the reason for lowering hp unless it was to high to begin with which is very rare.
#19 |
Harry I think you still feel that stock and super stock are a performance based eliminator. I do not agree with that. In the sixties they and early seventies it was based on performance. Today these eliminators mostly resemble brackets. Heads up in stock elimination account for between 2% and 12% of the total runs in the eliminator, less in super stock. Class is a side show to the eliminator. When class is run at a particular meet it does draw more entries. I am not saying there is no interest in class, just pointing out that is far less important than it use to be. The horsepower reductions are based on requests. Not everyone is going to be satisfied with the results.
Tony Janes 7941 STK, SS |
#20 | |
