Old 06-27-2010, 10:51 PM   #21
Liked 1,874 Times in 422 Posts
Default Re: Sleeveing a block
The balancer is the worst problem by far. I strongly suggest an ATI Super Damper.
Old 06-28-2010, 08:47 AM   #22
SSDiv6
Liked 1,603 Times in 583 Posts
Originally Posted by Alan Warman View Post
Well if I did not have bad luck, I would not have any luck at all. I don't think its chassis flex but I could be wrong. Here is a couple of things I noticed when tearing it down. The solid mount's are touching the frame. And the balancer I use is the stock solid cast hub. No rubber at all
You found the problem...like Alan said, get rid of the balancer and use either an ATI or BHJ.
