Old 06-17-2010, 05:14 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Drooze & Teuton
Originally Posted by Chris "drooze" Wertman View Post
Unless I missed something Jeff is running the 360 LA Combo...
Don't mean to be nit-picky, but to avoid confusion, the Challenger DP 360's are actually considered to be the "Magnum" version. I believe someone said the aluminum heads are re-cast Edelbrock Magnum heads with the Mopar logo. There should be at least a small variety of rockers for them.
A "LA" 360 typically refers to the original style which came with rocker shafts.The family includes 273, 318, 340 and 360. Excluded are what they call the "poly" 318 in the early-mid '60's and the later 318 amd 360's in the '90s that became the Magnum family.
.....You did say you were tired!
Old 06-17-2010, 05:47 PM   #2
Chris "drooze" Wertman's Avatar
Default Re: Drooze & Teuton
Yep....whooped....and you are spot on.....
Derher.....
And I do know better......
But yer 100%.....
I like the Poly 318's always have.....
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
