Old 06-09-2010, 11:49 AM   #1
Oclk Dlux
Default Re: WinterNationals 1973-1974
Danny,
In 1978, between Cal and I, we set the R/Stock stick record 5 times.
Times were in the high 13's
That was with real slicks, open headers, spools, electric fuel pumps ,and the new Cam Dynamics profiles (any lobe shape, stock lift, duration , and overlap)
None of that stuff was allowed in 72-74
Did Cal change his wagon from R/SA to Q/S? Here's a pic of it:
http://www.firebirdonline.com/blast_...st_index_A.htm
In the left column, scroll all the way down until you see "Cal Method". Click on his name to see the wagon.
Rich Hedden
6011 BF/S
Oclk Dlux is offline   Reply With Quote
Old 06-09-2010, 12:16 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
I believe NHRA factored the engine at some time in the mid 70's and at the time you were not allowed to adjust the wt. for a lower class. Maybe 6 or 9passenger model? Mark could probably let you know better since he ran one and that was 35 or so years ago.
Old 06-09-2010, 01:56 PM   #3
I believe NHRA factored the engine at some time in the mid 70's and at the time you were not allowed to adjust the wt. for a lower class. Maybe 6 or 9m passenger model? Mark could probably let you know better since he ran one and that was 35 or so years ago.
Could be several different factors there. You did need a 9 pass. to make "R" at that time.
Also ,back then you got points for setting records.
Another possibility ; I used to run Q at the R weight sometimes, before dialing under was allowed. Seeing I could run about .3 under the index, it worked out just about right.
Old 06-09-2010, 08:59 PM   #4
Geerhead55
Liked 5 Times in 5 Posts
Smile Re: WinterNationals 1973-1974
Thanks for the feedback Mark,,,thats a cool story about you and Cal. I can't remember how many guys ran the 65-66 wagons back then here out west besides Cal and Jerry McClannahan among others. I'm sure there were others.
Take care,,Danny Durham
Old 06-09-2010, 10:18 PM   #5
Tom Moock
Liked 10 Times in 6 Posts
Mark, I built my 1966 nova K/S in 1974, it had 10 in. wide L-60/15 size street slicks M&H i believe and Hooker fender well header, reground cam stock lift and duration, stock fuel pump,I paid $850.00 for my 283 built by Herman Chapman, The only way i remember what year it was because i had a new 1974 Ford pickup, Ran Indy that year and red lite in class. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-10-2010, 08:05 AM   #6
X-TECH MAN
Banned
Talking Re: WinterNationals 1973-1974
What did you do....cut the quarter pannels off to get the tires to fit?....lol.
Old 06-10-2010, 09:08 AM   #7
Tom Moock
X-Tech man, That was back when you had to use stock leaf springs, the tire`s side walls was the problem, had to use big hammer to make fit, Now you see nova`s with reverse off set wheels that wouldn`t fit in old days. Tom
Tom Moock 5704 STK
