Old 04-07-2010, 02:41 PM   #11
63corvette
Liked 362 Times in 105 Posts
Default Re: oil retention devices
Okay, I'll admit , my 12th grade education may not comprehend this, but I did some quick calculations.
If a diaper fits tightly, doesn't rub on the headers, doesn't drag on the ground, isn't near the steering ,and remains completely clean and dry, how could it hold 10 gallons of water, the equivalent of 35 standard size bricks?
Where does it go, into another dimension?
Mark what it comes down to is those diapers do not fit that tight on a S/G car. If you had one you would know it well.
If you have one on a motor there are lots of places for water to go.
Put a bunch of marbles in a jar and it looks full.
You can add sand to it and it fills all the gaps and it again looks full.
You can then add water and and you will be surprised how much water will go into that same marble and sand filled jar.
It happened I can assure you.
It was comical and like I said you had to be there to appreciate it.
Rick Cates
63corvette is offline   Reply With Quote
