View Poll Results: Should Indy Be All Run Field In Stock? | |||
ONLY 128 Fastest Cars under index |
133 | 66.50% |
ALL RUN FIELD |
67 | 33.50% |
Voters: 200. You may not vote on this poll |
Thread Tools | Display Modes |
Anybody that wants an all-run field can do that!
Just go to a bracket race! |
I do go bracket racing, it is called Stock Eliminator
Tony Janes 7941 STK, SS |
Scales. Fuel check. Heads-up runs. Qualifying. Teardowns. Class Wins. The possibility of being a DNQ. National Records.
I have had runs disallowed due to fuel and weight issues. I've DNQ'd at Indy before (2000). I've torn down for setting National Records. All while racing Stock Eliminator. Never done any of the above while bracket racing. Indexes too. In bracket racing, no one tells you you can't dial slower than (insert ET here--except for class ET breaks). Otherwise, in Stock, I could have run my daily driven 13-14 second '95 Camaro in D/SA and been OK, as long as it met the safety requirements. And in brackets, you don't have people telling you what blocks, heads, transmissions, spec numbers, etc are, and what you have to run, and you can't be DQ'd in Super Pro because of a cylinder head issue. About the only similarity between Stock and brackets is a two dollar bottle of shoe polish.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 Last edited by Mike Carr; 04-06-2010 at 11:07 AM. |
#4 | |
Liked 293 Times in 65 Posts
