Old 03-26-2010, 09:10 PM   #9
Fred Popov
Default Re: Another bogus hp rating.
Originally Posted by Charley Downing View Post
Greg come on 290hp. 245hp maybe.
Compare it to a 283ci Chevy like Wade Owens which is rated around 220HP (NHRA). Wade went -1.10 (11.75) at Belle Rose. There is no way the Ford 281ci with a little bigger throttle body and cam can make 75 more hp then say Wade Owens car. The 235 hp 281ci in J/SA is no better the Wades combo in M/SA. Heck I will take it one step further by comparing it to Johnny Fishers 360 dodge. Fisher car ran 11.65 @101mph in K/SA at INDY. Which means he could have ran somewhere around 11.50. I fail to see how this ford combo is any softer then these two combos.
Just so I’am getting your point right. You feel that a 281ci motor will make the same HP as your 350ci motor with a Holley. That is too funny. If that ford motor makes with in 25hp of yours you need to find a new engine builder.
You should take a look at the flow numbers on these Ford 3 valve heads. (About 225 intake and 190 CFM exhaust ~ Stan Weiss Head Flow Database) Factory stock they flow better than the Chevy LT1s. At these flow numbers these engines are capable of 450+ HP.
Fred Popov is offline   Reply With Quote
