Old 03-01-2010, 05:59 PM   #6
Robert Swartz
Robert Swartz's Avatar
Default Re: NHRA blueprint guide-part crossover?
Originally Posted by Dragsinger View Post
Robert,
I do not know about the intake, however, be sure you understand the "factored" horsepower rating is 287. Thus, it can be stated as 350/165/287
And speaking of the Crate Motor combinations, I like them. If you have some IHRA races in your area is is a valid option. In addition, the new AHRA will run the Crate Motor combination in stock, thus, another option.
In that 1979 Firebird, the 350/330/340 Crate Motor with Vortec heads is a stout runner.
Thanks Larry. Yes, I understand about the refactored HP. This is just another option, I'm looking into. My thought is to research the NHRA combo. Then start scratching around for parts.
I hope this crate motor combo will be stout. My plan kind got schewed(sic). I had intended to get the body and chassis prepped first. I've gotten steered more in the direction of collecting motor parts. After purchasing YOUR heads and intake. I've acquired a block and a couple of donor cranks, hope one out of two will be suitable. I've also gotten a set of new Ross pistons. Same guy has a cam and a torque converter I'm going to get as well.
My biggest hangup at present. I'm just lacking a couple decent cash infusions. I'm hoping to, maybe, be able to run a couple combos late this year. The stars are going to have to align just right for that to happen.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
