Hey guys can you help me find the class minimums in stock? Or if you know what they are for G/SA and H/SA? Thanks.
Family Tradition Racing |
It depends on the combination being run. Find out what NHRA factors your engine at then multiply that by 11.0 for G/SA then add 170lbs for driver weight and that will be your minimum weight. In example my car is rated @ 293hp so. 293 X 11.0 = 3223lbs , now add the 170lbs for driver, which = 3393 lbs. I think you round down to 3390lbs minimum weight for G/SA.
Dusty Lowell #1773 STK F/SA |
Ok thank you for the help.
