#1 | |
Liked 7,742 Times in 1,740 Posts
The only other thing to consider (other than having a car vs. finding and buying a car) would be the difference in weight between the two. The Monte Carlo has to weigh only 3170 to make U/SA while the Camaro has to weigh 3770. I like towing light cars.
#2 | |
Liked 5,124 Times in 1,953 Posts
I actually didn't realize the hp rating on the 267 was that low. It might be worth a shot for someone willing to spend the money on the rear end. Maybe some math major could analyze the specs and give us a hp and torque potential.?
Liked 54 Times in 18 Posts
Keep it coming guys, I love the modern low class tech lessons. Must be from my old P/S junior stock days & old age.
It wouldn't be too expensive if he could find a GN rear!
Liked 66 Times in 37 Posts
I would not put 1 cent into that combo but I have a brand new set of .060 cast pistons in the box for FREE. It's the carb! The 305 2G is a possible and by the way I have one for sale HAHA just needs the motor. I have not had much luck with any two barrel.
Liked 169 Times in 53 Posts
We're putting a Moser 12 bolt in the car. I realize it's overkill for a U car but I have a few ring and pinions of various ratio's as spares so we can see which one will work the best when we get it running. we're starting out with a 5.13 and go from there.
Liked 166 Times in 71 Posts
A side note on the g body rearend problem, it's quite easy to make a 8.5 from a 78 up caprice fit, needs to be narrowed, and you need to make a set of upper arms similar to a body swap arms but it's cheap and easy if you can fabricate.
Liked 476 Times in 117 Posts
best of luck...
...dig up steve & bear tarrance for carb help, he's the only one ever made the 1/2 q-jet work, and stay away from bob shaw & that caddy, he can be pretty depressing ![]() oh yeah start drinking beer immediatley, and welcome to U/SA the class that has fun ! captain jack
Jack McCarthy 3609 STK "the Captain" |
