Old 02-24-2010, 02:54 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default wheels spacers
What problems could you run into if you use a wheel spacers on the rear? Need to use a 1/2 spacer to fit wheels. Thanks.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-24-2010, 03:20 PM   #2
W J
Default Re: wheels spacers
You're going to put some serious stress on the wheel studs using a spacer, 1/2" is quite a bit, as well. Are wheel spacers even allowed at the track? I feel they are dangerous for race applications....just my opinion, though...WJ
Old 02-24-2010, 03:42 PM   #3
race watcher
If you use lugs that go threw the spacer the same depth as it would go threw the wheel it would be like using a thick wheel. The spacer should be good quality and fit snug around axle flange. If you were to mount the spacer to the wheel is it still a spacer or a thick wheel?
race watcher is offline   Reply With Quote
Old 02-24-2010, 04:36 PM   #4
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
I don't use them, but if I had to I would get a high quaility set made from billet material and use the large wheel studs and torque to manufacture specs.
Wade Mahaffey is offline   Reply With Quote
Old 02-24-2010, 05:17 PM   #5
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
More people are using them then you think! Its tough, some of the back space on wheels only come in 1.0" increments. 1/2" is quite a bit though. 6cyl app might be fine.
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 02-24-2010, 05:28 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
1/2" is the max I would ever use , and I will only use them on a car with 5/8" studs. .....I recently had to put 3/8" spacers on my car to clear the calipers with a new set of rear wheels..almost a thousand HP and no problems .......A lot of the old zinc die cast spacers are to blame for the bad rap spacers have ,the surfaces were not parallel and they were soft ,so the lugs often came loose. ......S&W and others make excellent steel spacers that are perfectly safe to use. .....Tom
Old 02-24-2010, 05:42 PM   #7
Ed Carpenter
Yes I have 5/8 studs. I will go with either mark williams or baer billet spacers thanks. Ed
Ed Carpenter
Old 03-02-2010, 11:22 PM   #8
Marine One
Marine One's Avatar
Go too hard of a metal on the spacer and you eat into the studs faster. I've seen wheel spacers cause studs to break and wheels to come off. Not good.
Marine One is offline   Reply With Quote
Old 03-02-2010, 11:56 PM   #9
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
I run 1/2 spacers on my car with no problems. I do have 5/8 studs. Make sure they are a good billet piece like Mark Williams, not the junk Mr. Gasket cast ones. You will be fine!
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
Old 03-03-2010, 01:36 AM   #10
treessavoy
Liked 4 Times in 4 Posts
Jegs has 1/2" billet spacers for $64.99. pn: 555-65052.
Multiple bolt patterns.
JimR
Jim Rountree
