Old 02-24-2010, 04:03 PM   #1
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Default Re: Log onto Nhra
same problem, says I am logged on somewhere else.
Dyno is online now   Reply With Quote
Old 02-24-2010, 04:26 PM   #2
FED 387
Liked 333 Times in 180 Posts
look on very bottom of the NHRA screen in tiny print you might find "cancel"--- push it and you might be able to log on----worked for me when it said I was logged in at another location---Comp 387
Old 02-24-2010, 04:28 PM   #3
FED 387
Sorry "RESET not cancel "all the way to the right side in the small print--Comp 387
Old 02-24-2010, 04:33 PM   #4
doublet
Seems I've had issues off and on ever since they went to the new format. I don't go to that site nearly as much as I used to.
doublet is offline   Reply With Quote
Old 02-24-2010, 05:04 PM   #5
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 17 Times in 7 Posts
when it comes up with the log-in page...look above that and click on logout...that should fix it. then when you click on NHRA.com, it should take you to the home page.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
