Old 02-15-2010, 09:04 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Wink roll bar
almost ready to start the roll bar in my 97 Firebird and was wondering if anyone knows the weight saving CM to MS and the cost difference. Is the CM worth the price ? Mike
Mike Savelle is offline   Reply With Quote
Old 02-15-2010, 09:16 AM   #2
art leong
Default Re: roll bar
Check with S&W their bars fit very good and are resonable. On my car the mild steel was about 50 pounds heavier. But the chromemoly was more than twice the price, and it limited who could install it.
Art Leong 2095 SS
Old 02-15-2010, 09:17 AM   #3
Chuck Norton
Liked 89 Times in 19 Posts
Good morning, Mike,
Yes. Not only is it lighter, it is less bulky and it's stronger, plus it allows you a margin of flexibility in deciding where to put the weight. There is also a consideration of resale value.
c
Chuck Norton is offline   Reply With Quote
Old 02-15-2010, 09:22 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Worth the price and the weight. ....Late F body is 45-50# for a cage,25-28# for a rollbar. .....I've used a lot of S&W'S kits,it's not worth the time for me to bend one custom since theirs fit well.........Tom
Tom Goldman is online now   Reply With Quote
Old 02-15-2010, 09:55 AM   #5
Mike Savelle
Smile Re: roll bar
thanks for the replys . I'll check out the CM tomorrow. Mike
Old 02-15-2010, 10:07 AM   #6
denny harvey
mine was 67lbs lighter then mild steel,its a full cage in a 2ed gen camaro..sorry for the size of the pic,i cant make it smaller...denny
denny harvey is offline   Reply With Quote
Old 02-16-2010, 02:44 AM   #7
Jeff Lee
Jeff Lee's Avatar
And less cracks in the body with CM also. Like Chuck said, keep it light and strong so you can place the weight where you want it. Amazing what an extra 50#'s in the trunk will do for traction!
Jeff Lee 7494 D/S '70 AMX
Old 02-18-2010, 12:28 PM   #8
hookdaddy
Liked 8 Times in 3 Posts
That's probably the best reason for moly. Keep in mind if you got a 1' piece 1-5/8" BAR stock in moly and mild steel they would both weigh the same. But since chrome moly is much stronger the NHRA & IHRA allow moly cages to be made of tubing that is 34% thinner than it's mild steel counterpart (.083" wall vs .118" wall) Therefore a moly cage will be 34% lighter than mild.
Two other things to keep in mind - since moly is lighter - shipping cost on the kit are lass but since it requires TIG welding, unless you can weld it yourself , installation cost are bound to be higher.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
