Old 02-13-2010, 08:51 AM   #18
hemidup
Default Re: Drag Pak Engines
Originally Posted by Eric Merryfield View Post
Anyone find/know the combined weight for the new motors on the NHRA's site? Seems to be MIA from the accepted products list! Maybe I am just missing it.
CID YEAR PISTON# FACTORY HP
MINIMUM
COMPRESS.
HEIGHT PIN DIA. RING GROOVES
MIN
DISTANCE
FROM TOP
OF UPPER
RING
GROOVE TO
TOP OF
PISTON
*Ref only*
PISTON
WEIGHT
*Ref only*
ROD
WEIGHT
*Ref only*
PIN
WEIGHT
*Ref only*
RING SET
WEIGHT
MINIMUM
ASSEMBLY
WEIGHT
By combined weight, are you asking what a completed engine weighs? If so, 460# less fluids.
hemidup is offline   Reply With Quote
