Old 02-02-2010, 02:41 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Smile Re: Killer combo!
Originally Posted by greg fulk View Post
I just found a killer combo.....1991 Ford Econo Line van with a 302 ....Natural U/SA!!!!!
I thought you were joking, till I looked! 14.85 with the new index a bit porky though @ a min weight comp weight of 4470. Think of the sponsorship potential, 85 yards of add space, blotting out the sun for the spectators, moving at well highway speeds so they can even read the fine print.....Do you even need a cage at that class?
Frankly it would be an easy one to do, for practically no dough....
Eric
Eric Merryfield 1883 STK
Old 02-02-2010, 05:20 PM   #2
mtkawboy
Liked 54 Times in 18 Posts
Default Re: Killer combo!
They came with 4 speed OD transmissions behind the 300-6 and 302 V-8, so you could run one
mtkawboy is offline   Reply With Quote
Old 02-02-2010, 05:28 PM   #3
Ron Middleton
Liked 12 Times in 4 Posts
Try to find one. Not as easy as you might think.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 02-02-2010, 05:29 PM   #4
mtkawboy
Tried to edit that but it wouldnt let me. They came with the 4 speed OD in the late 70s & early 80s but i dont think they did in 91
Old 02-02-2010, 05:32 PM   #5
mtkawboy
Not very strong anyway , 4th gear drove thru the cluster to get the OD gearing. Some had bushings, the better ones had bearings in the cluster. Nothing a Jerico wouldnt fix
