Old 01-22-2010, 05:40 PM   #1
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Re: Locking Dipstick
The Lokar unit is hard to put in on your back. The locking nut is a tight fit and there isn't much room for a wrench to turn the top piece on a t400. The trans brake selinoid is in the way. Doing it on a rack would probably be easier. Having someone else do it would be easier yet. Us old guys aren't as flexible as we once were.
Floyd Staggs 787 SST
Old 01-22-2010, 06:36 PM   #2
Floyd Staggs
Update on Lokar dipstick. If you have a door car with not much firewall clearance the trans mount dipstick won't work. You can't get to it to fill with fluid or release the dip stick. Go with the firewall mount.
Anybody want to buy a Lokar locking dipstick trans mount for a turbo 400?
Old 01-26-2010, 12:45 PM   #3
Bob Verwold
Bob Verwold's Avatar
I now have an older B&M dipstick that has the rubber on top (inside) when you tighten up the handle on top it expands the rubber. Is this considered to be a locking dipstick or does it need to actually lock down ???
Bob Verwold is offline   Reply With Quote
Old 01-26-2010, 03:04 PM   #4
63corvette
Liked 358 Times in 103 Posts
Bob, that is exactly what my Hughes is and it is on the approved NHRA list.
The only difference is my Hughes is a cam expanded rubber seal like the later model GM dipsticks.
I guess we will see when we go to the first race.
I also am carrying a threaded B&M in case there is an issue.
My 2 Cents
63corvette is offline   Reply With Quote
