How big of a front tire can I run on my 67 Firebird? Have all "stock" suspension on it. Nothing moved or enhanced... Want the biggest I can get without rubbing.
Thanks in advance! Ken |
Ken ,That would depend on the offset of the rim.
Good point, thanks Mark.
They are 15x4 draglites, but I will have to measure tomorrow. Not sure if there is more than one offset on that size or not. |
3.5 draglites with 1.75 back space
what fits? thanks Ken |
Liked 5 Times in 3 Posts
27.5x15 will work just fine
Liked 13 Times in 7 Posts
Running the Hoosier 18107's with no problems.
# Tire Size: 28/4.5-15 # Tread Width: 4.5" # Approximate Diameter: 27.7" # Circle: 87" # Recommended Rim: 3.5 to 4" # Measured Rim: 4" # Section Width: 7.6" # Tire Weight: 12 lbs
N/A |
i dont know if your trying to obtain more rollout for r/t, taller ride height, or just the look of having a filled-out fenderwell but i dont believe they make anything bigger than a 29" in which case theres not going to be much difference from the 28" that you have now. if anything, borrow a set of 29's if you can just to stick on and see how much room you have
