#41 |
Records have been removed from the NHRA site.
Ray Menard SS/CS (SS/DM & SS/EM) #7386 |
#42 |
We have been fighting the basic same thing with IHRA for a while. Crate Motor indexs are alot softer than the regular stockers. I guess, the bottem line is the fast guys will still be fast, just have more room to be faster now.
Mark Beaver #290 C/SA 98 Camaro, SS/J-KA |
#43 |
Did anyone notice this line near the end?
"Runs of 1.250 or more under the index will be reviewed and adjusted Tuesday following the event. Runs at National Events, Divisional Events, and National Open Events, including those at altitude factored race tracks, are included in the 1.250-second-or-more-under analysis". If I am reading this correctly, this means that a car at Altitude that runs -1.250 now gets HP the same as a car at Sea Level that runs -1.250? If so, I applaud NHRA for fixing this glaring disparity.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#44 |
Liked 325 Times in 50 Posts
Mike, I think it has been that way. Wasn't that the big deal with Sorenson last year when he dumped the water or something? It's the same as running 1.55 under in 2009. And when the semi-annual adjustments, the new average will be .15 faster than last years 1.00 under average, but with the.3 drop, the effect is a 1.15 under in 2009 average sorta like the 396 guys are commenting about.
Jeff Teuton 4022 STK |
#45 |
Ah Ray, as of this time the records are still there.
Jeff, the flap with Sorenson was he ran -1.40+ the sea level index at an altitude factored track, then they say he didn't, and pulled the water trick. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() Last edited by Jim Wahl; 12-18-2009 at 09:12 PM. |
#46 | |
Liked 1,874 Times in 422 Posts
Actually, that's a bad idea. Why? Because NHRA does not consider the current local weather conditions at factored tracks, and adjust the factored index accordingly. I've seen days where the actual conditions at Denver, a factored track, were 1500' better than Bristol, an non factored track. A track that is factored at 3000' could see local current weather that was actually closer to 1900'. Since they don't adjust the factored indexes to account for that, it'd be ludicrous put HP on a car for running 1.25 under the factored index. If a car were to run 1.250 under the sea level index, then of course, it needs HP. But it already works that way now.
Alan Roehrich 212A G/S |
#47 |
Hi Jeff. Yes, I remember the Sorenson deal. A car had to run -1.40 (back then, -1.25 now) under it's sea level Index. Meaning Joe in B/SA, if he ran 10.149 or quicker, he got HP regardless of elevation. Difference was, 10.149 is -1.401 under sea level, yet something like -1.77 under the Boise Index.
1 633 B/SA Hal Sorensen, Vancouver WA, '69 Camaro 10.159 11.93 -1.771 The statement in the new AHFS article states: "Runs of 1.250 or more under the index will be reviewed and adjusted Tuesday following the event. Runs at National Events, Divisional Events, and National Open Events, including those at altitude factored race tracks, are included in the 1.250-second-or-more-under analysis. This is done to better react to any out-of-line indexes or under-horsepowered combinations. Therefore, at all such events, a 3.25 percent horsepower adjustment or index reduction will be initiated Tuesday following the event. The decision to adjust horsepower or to reduce the index will be at the discretion of the NHRA Tech Department". So is that -1.250 under the sea level Index, or the particular altitude adjusted Index at that event?
#48 |
You're right, Jim,
I looked in the wrong menu. Thanks for clarifying.
#49 | |
B/SA, sea level Index 11.55 (old index). You run 10.150 or quicker (more than -1.400), you get HP. B/SA Boise Index, 11.93 (old Index). You can run 10.151, which is -1.779, but results in NO HP, because the car didn't run -1.40 under the 'sea level' Index. If the factors are indeed not a little suspicious, then a B/SA that runs quicker than 10.430 (more than -1.40 under that particular adjusted Index) at Boise should receive HP. Am I missing something?
#50 |
Liked 4 Times in 2 Posts
this did nothing but penalize the part time racer trying to go out and compete, factor the fast combo's as needed, this is a crock
