Old 12-07-2009, 09:35 AM   #23
BlueOval Ralph
Banned
Default Re: dot compliance
The key is is the tile to both in your personal name or buss name?
Originally Posted by 63corvette View Post
You only need a CDL and all the documentation if you are driving a commercial vehicle.
I have been through all of this this year.
I have a diesel pusher motor home which is listed with a gvw of 32,000.
I need and have a class B non commercial.
I can tow a trailer of 10,000 lbs gvw or less with that license.
I can get a class A and tow a trailer of more than 10,000 gvw which is also good for the 26,001 gvw pickup and trailer combination.
As long as you are not a commercial operation you do not need the CDL.
The Class A & B use the same testing programs as the CDL you just do not the the physical and log books. I in fact had to parallel park my 40 ft motor home and never touch the curb and be within 18 inches of the curb both front and back inside a spot that looked like was about 60 ft wide without jockeying it. Not an easy task even with practice before doing it and I will never do it again.
My Class B is good for 7 years just like a regular class C and the CDL is good for only 2 years at a time I believe.
These are all Federal Rules and each state should be the same.
The way the Rules are applied is as wide spread as the number of officer's enforcing them.
Been There And Done It This Year
BlueOval Ralph is offline   Reply With Quote
