I has a 8 point cage,The body is rust free so I don't have to replace the floor and weighs about 3300 lbs. I will probably keep the 400 for now. My goal is to get the car on the track by spring so if it not broke I am going to keep it. I am looking for a Big block for it to run.
#2 | |
I'll see what my machinest has laying around. You might consider a GM crate 454 or 502 or if your budget permits a 572. Billy Baer
Bill Baer 3391 SC, 339B SC, QR |
Found a 502 going to pick it up next week....thanks Bill...I am going through the car cleaning things up and noticed that the car still has stamped rear controll arms... would it be worth the money to replace them now with after market or just keep them...If yes is ajustable the way to go..Trying to stay in a budget but my safety has no budget......
400 trans,reverse valve body, shfter, trans break and 5500 stall.
Remember, that's what everyone else has. Where is your edge? The nice thing about a powerglide is, it doesn't try to MURDER the tires coming off the line like the 400 will. |
Whatever you wind-up running, you should always remember it's just for fun... very few bracket racers make a living at it. That said, I always try to find something that went well... the car ran quicker, I cut a better light, went more rounds, helped a fellow racer, etc. If you don't look at it that way, you might get discouraged and give it up... after sinking a bunch of money into your car. Now, go have fun!
![]() "By-Run" '68 Barracuda 340-S 4-Speed 11.34 @ 118.6 mph |
Liked 216 Times in 77 Posts
I raced for the fist time on aug 17 1986 3 days after I turned 16. It was very obivious that it was my first time and one of the local hitters came up to me and said "1st time" I said yes any advise
here is what he told me. "Quit now and buy a boat LOL. You can fit more ladies in it, they will usually be wearing less clothes, they like it better than the racecars so you wont get as much complaining about it and unless you do something stupid you wont have to work on it very much to have fun but if you like it and are going to keep coming up here to the track make for dam sure you have fun because you can go from feeling like your on the top of the world to the dumpster in this sport in less than a few seconds if your having fun that dumpster does not feel so bad. so just go have fun would be the best advise I could give you the rest will come as you get more seat time. |
#7 | |
In my experience the bolt on ladder bars and bolt onslapper bars don't work very well and just cover up other problems (slop) in the GM stuff. Some time back Mr. Gasket and Genuine Suspension sold "no hop" bars that relocated the upper rear control are attachment points higher and improved the suspension geometry but in my experience they tended to loosen up after some use and I am therefore very leery of them. You also as a minimum need to have the front end alignment checked to verify that you have as much positive caster as possible. You might also consider replacing the front A-arm bushings and coil springs with Moroso trick Springs and 90/10 or front drag shocks which will increase the travel of the front end which can help plant the rear tires. If you consider the aftermarket control arms they till give you the ability to adjust the pinion angle which could be useful but I myself have no experience playing with pinion angle for chassis tuning I have seen some very fast cars with the stock or near stock chevelle rear suspension. All of this may be overkill but, I like you, don't trust those stock stamped steel control arms and I do know that any slop in the GM suspension will result in wheel hop and will break stuff. Hope this helps
Thanks, I am going into this to have fun and hang with friends. I am going out to the garage to look at the mounting holes and start boxing them in. Thanks for all the advice keep it coming... Happy holidays to all....
Make sure your cooling system and battery charging system are up to snuff for hot laps !!!
Don't lose a race because your engine is hot or the battery is not charged enough !! :-) |
It has a electric water pump...I looked at the rear control arms the rubber in the bushings are rotted the arms are stock stamped steel...I am looking at after market...I was thinking of non adjustable lower and adjustable uppers...Any advice...Thanks to all for the help and Happy Holidays.....
