Old 11-13-2009, 02:41 PM   #5
Lambertcars
Default Re: 2004 silverado instrument cluster guages
Your Dealer that you talked to is overcharging you for the inst.cluster,I work at a Chevrolet Dealer in the Service Dept.and when a customer has a promblem with the spedo,tach or any gauges we connect the Tech 2 to the diag.plug and check the cluster gauges and it will tell what gauge are bad,then we get the part number of the cluster useing the Tech 2 and the Parts Dept will get a reman cluster overnight and replacment of the cluster and reprograming is about $375.00 for everything.also the years that we see the promblem is 2003-2005.Dont let the Dealer you are dealing with tell you that you have to have a new cluster,when they can get a reman.for your veh.
Lambertcars is offline   Reply With Quote
