Old 11-06-2009, 07:49 PM   #1
T Hall
T Hall's Avatar
Default Weld Wheels,Mickey Thompson slicks, Moroso Drag Special fronts
Weld draglites wheels. Back ones are 15"x 10" with 5.5 back spacing, they have Mickey Thompson 9" x 29.5' x 15" Slicks on them with 48 passes. They are mounted with tubes,
Fronts are Weld Draglites 15" x 3.5" with Moroso 7.10 15 28 Drag Special tires. They are like new and mounted. I will also brake them down and sell as following...... 4 wheels, both slicks, $500. or....4 wheels only for $400. NO TRADES, buying new style wheels and radial slicks.
$600 for all plus shipping. 614-599-6546 Tony
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
Old 11-08-2009, 09:27 AM   #2
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: Weld Wheels,Mickey Thompson slicks, Moroso Drag Special fronts
What is the bolt pattern and are the rims drilled for screws?
thanks
Kirk Morgan is offline   Reply With Quote
Old 11-08-2009, 06:02 PM   #3
T Hall
T Hall's Avatar
thanks
They have chevy bolt pattern, but I believe that the drag liteswill fit any car because of the number of holes, I could easily be wrong, and yes they are drilled for slicks. If interested I can send pics. Thank you.
Tony Hall
3545 S/ST
