Old 10-23-2009, 06:35 PM   #11
magnumv8
Default Re: 727 or 904 behind Cummins in a Ram Truck
What's neat and why you see it alot is the Cummins 4BT and 6BTdiesels have been used by Dodge, GM and Ford in various chassis over the years (a long time) and the key item is the adaptor plate....this isn't an after market item, but a necessary piece to make the engines compatible for all the different manufacturers.....bread trucks were/are great places to find these engine/trans combos and since Ford and GM both built them the chassis would usually have the 4BT and either one of the matching trannys with the appropriate adaptor plate (the 4BT and 6BT generally use the same adaptor.....if you go on EBAY and do some general searches on 4BT, 6BT in parts there usually is some things there to let you see what these are......
D. L. Rambo
magnumv8 is offline   Reply With Quote
Old 10-23-2009, 07:00 PM   #12
magnumv8
I forgot I had this web site in my favorites
http://www.4btswaps.com
D.L.Rambo
Old 10-24-2009, 10:44 AM   #13
Chris Hill
Liked 244 Times in 26 Posts
D.L.Rambo
Nice site. My main question is what to use for trans and converter and how much power can be made reliably and without spending a ton of money. Application would be 2wd and probally a car or 1/2 ton pick-up.
Chris Hill
Old 10-25-2009, 08:12 AM   #14
340Cuda
Liked 805 Times in 341 Posts
Originally Posted by Curt Rees View Post
Chris,
I beleive the 1st generation of Dodge diesels, 1989 through--??, came with Allisons. My 02 was a Chrysler (junk) product.
I am not sure of the year that the Allisons were dropped. Again, maybe someone else might shed some light.
#5457
Curt Rees
Curt,
I with the exception of the Aisen transmissions that come in the new Dodge Cab and Chassis, I don't think any Cummins powered Dodge has ever had anything but a Mopar automatic of some sort behind it. Until the six speed automatic that is now availble, the manual was always the better choice.
Bill
Old 10-25-2009, 10:19 AM   #15
Curt Rees
Liked 251 Times in 51 Posts
Bill,
I just googled the '89 Dodge diesel pickup options. The 1st generation could be had with a manual or a 3 speed automatic. I could not find anything on what the model of the auto was.
All 3 of the Dodge's I have owned had a Mopar automatic for a transmission. As stated the 2002 trans was junk., I think only produced 1 year.
The best thing about my 2005 is fuel mileage. 22+ at 75 on the interstate! 18+ stop and go.
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is online now   Reply With Quote
Old 10-25-2009, 11:43 AM   #16
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Originally Posted by Chris Hill View Post
Will a Mopar 727 or 904 transmission (sb or bb bellhousing) work behind a 5.9L cummins engine?
I'm thinking the OEM application would be a 1991 or 1992 dodge pick-up.
Thanks,
Chris
Chris,
To date, the Cummins has had six automatics put behind it. They are:
1) 727-Chrysler built
2) 47RH-Chrysler built-basically a 727 with an OD unit and Hydraulic Governor
3) 47RE-Chrysler built-basically a 727 with an OD unit and Electronic Governor
4) 48RE-Chrysler built-basically a 727 with an OD unit and Electronic Governor-High Torque Capacity
5) AS68RC-Built by Aisin Seiki-Six Speed-Fully Electronic-Has PTO Provision
6) 68RFE-Chrysler built-Six Speed-Fully Electronic
Starting with the 47RH, the alpha-numeric code describes the model designation:
The 4 means 4 forward gears---- a 6 means 6 forward gears
The 7 means high torque capacity-----an 8 would be the highest torque capacity
The R means rear wheel drive
The H means hydraulic control----the E means Electronic Control-----the FE means Fully Electronic Control
As already stated, the Cummins has it's own bellhousing pattern or block plate pattern-however you want to describe it. It is different than the SB and BB patterns. As already stated you could switch the block plate if you wanted to try a Ford or GM transmission.
If you are not going to use a controller, the 727 or 47RH would be your only option as they require no electronics to function.
Send me a PM if you have more questions
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 10-26-2009, 04:45 PM   #17
dragst racer
You might call A&A Transmission in IN. or check out their web site they are good with automatics especially those Chrys. Phone 317-831-3066 or aandatrans.com or aandatransmission.com
dragst racer is offline   Reply With Quote
Old 10-26-2009, 05:57 PM   #18
Jeff Teuton
Liked 325 Times in 50 Posts
89-91 had a 727 trans. Will fit a Viper or Iron V10 and the Cummins.
Jeff Teuton 4022 STK
Old 10-28-2009, 09:12 AM   #19
Dave Tincher
Thumbs up Re: 727 or 904 behind Cummins in a Ram Truck
Here is what I did. I have a 89 jeep wrangler with a 4bt cummins with twin turbos estimated around 130 hp 550 ftlbs I am using a 700 R4 with the updated (4L60) internal parts, so it has o.d and lock up converter. So you can use anything you want. You just have to make it work or spend around $1600 for the adapters,
Dave Tincher 306 SS
Dave Tincher is offline   Reply With Quote
