Old 10-14-2009, 09:14 PM   #1
Dennis Paz
Liked 5 Times in 3 Posts
Default 283 head gasket
Help
I cant remember the part # for the factory steel shim 283 head gasket.
Dennis Paz is offline   Reply With Quote
Old 10-14-2009, 10:33 PM   #2
doug schriener
Liked 7 Times in 6 Posts
Default Re: 283 head gasket
Dennis-The 307 head gasket {.017} I used was 3995633. Doug Schriener
doug schriener is offline   Reply With Quote
Old 10-14-2009, 10:47 PM   #3
Dennis Paz
Thanks
Old 10-15-2009, 07:25 AM   #4
FED 387
Liked 333 Times in 180 Posts
Question Re: 283 head gasket
3830711 ???
Old 10-15-2009, 11:13 AM   #5
Dennis Paz
3830711 is a 4 inch bore.
Old 10-15-2009, 11:37 AM   #6
FED 387
I'm sorry was
thinking what we used but yes the block was overbored---comp387
Old 10-15-2009, 06:04 PM   #7
Jeff Lee
Jeff Lee's Avatar
FYI - I just ordered a set of Cometic gaskets. They'll make them any bore and the minimum thickness is .027".
Jeff Lee 7494 D/S '70 AMX
Old 10-15-2009, 06:53 PM   #8
FED 387
flat out will make them too--Comp387
Old 10-15-2009, 07:30 PM   #9
james schaechter
Liked 1,436 Times in 299 Posts
Exclamation Re: 283 head gasket
We use Cometics on our 283s (stockers). I reuse them in teardown multiple times. We used to run the shims, but they are hard to find. Tried Coppers and they were a pain. The Cometics are nice.
James Schaechter 3163 STK
Old 10-15-2009, 07:58 PM   #10
Dennis Paz
Cometic tells me 100.00 each.
Chevy gasket 12.00 each.
