Old 10-13-2009, 09:42 PM   #1
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: 64 Plymouth GT/EA in Ennis
T-10 was also used in 1963
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 10-15-2009, 08:42 PM   #2
340Cuda
Liked 800 Times in 337 Posts
Yes, I think you are correct, but not with the max wedges. 383s and 361s?
Thanks,
Bill
Old 10-15-2009, 11:21 PM   #3
Mopar Steve
Thanks,
Bill
383 B-bodies only if I remember correctly.
Mopar Steve is offline   Reply With Quote
Old 10-17-2009, 07:07 PM   #4
rickkolber
I would have sworn that that 64 aluminum hemi cars came from the factory with hood hinges. I just dug out a book I knew I had that shows a 64 Dodge aluminum hemi car which looks to be at the end of the assembly line getting the once over inspection. It has the magnesium front wheels and what appears to be four rather large wing nuts. Sorry I can't post pic's to back this up, but the book is MOPAR ..THE PERFORMANCE YEARS by Martyn L Schorr ..copyrighted 1982...picture is on page 12. The picture is of a NON altered wheelbase car. Hope this helps. I think what created the problem on whether they had hinges or not is the fact a lot of 64 max wedge cars were converted to hemi status...my 2 cents.
rickkolber is offline   Reply With Quote
Old 10-18-2009, 07:35 AM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: 64 Plymouth GT/EA in Ennis
I hate to say...."I TOLD YOU SO"
Old 10-18-2009, 11:15 AM   #6
James L Miller
Liked 25 Times in 16 Posts
The correct answer seems to be BOTH! I e-mailed a few folks I know that were around from the old days and have researched the cars. Here is a response from Jim Schild who wrote several books on the SS cars.
"There is no debate or should not be. The 1964 Hemi sedans were built exactly like a standard car on the line with the aluminum hood painted and installed with hinges in place. The hinges were removed and the pins and wing nuts installed at the final assembly facility. I am positive about the sequence because the original cars I have examined and original photos show that the body was not painted under the hinge and the hinge attachment area of the hood panel so the hinges were removed after the body was painted. Red primer or rust was visible under where the hinges would have been.
The white Dodge you see pictured in my books is in the delivery area at the Hamtramck plant being prepared for owner pickup at the Lynch Road U-Drive lot. All work has been done on the car at this time and it has left the assembly plant area. Pete Haldiman's book even has the name of the two guys working on the car. The original threaded hood pins may have been aluminum but they were flat on top.
I know of only one restored car with hinges in place and that is the white Dodge now owned by Todd Werner in Florida. The original owner (Barnes Drilling service) had the car being prepared at Landy's place in California and Dick's brother stepped on the original hood and bent it so they installed the hinges so the hood would not be removed. This particular car also has an incorrect battery mounting and a questionable right side upper control arm support. I am not sure about the authenticity of the control arm support but many restorers install the 1964 sedan batteries incorrectly because they found the Max Wedge brackets in place and assumed they were used. The brackets were there but they were not used on the Hemi sedans. They were used on the 70 1964 Hemi hardtops which had Max Wedge type battery mountings.
It may be interesting to note that both the 1964 and 1965 Hemi lightweight hoods came into the plant unpainted but with the scoop already installed. Sealer was installed around the perimeter of the scoop and the unit was painted as an assembly. All of the scoop fasteners and J-nuts should be painted body color."
Mopar 2 Ya!
Old 10-18-2009, 11:21 AM   #7
James L Miller
More from Jim about Lee Smith's car:
"I see Lee Smith is in your email group. He picked up his white 1964 Plymouth Hemi sedan at Lynch Road in 1964 and he knows how they were delivered. I have a copy of his 8 mm movie from when he picked up the car and you can see the bare spots where the hood hinges were attached. I have also inspected and photographed an original 1964 Plymouth and the same thing is present. A 1964 article about Hayden Profitt's Plymouth also shows the bare spots on the hood. The cars were raced with the lift off hoods."
Hopefully I'll hear from Lee about his testimony and recollections. This should pretty well clear up the debate unless Lee or someone else contradicts this.
Mopar 2 Ya!
Old 10-19-2009, 11:07 PM   #8
James L Miller
I found a document from Chrysler Product Planning addressed to Wally Parks on what appears to be the "6.40" cars (aluminum bumper, doors, light glass, single headlight and the mag wheels on the front). From the description, it sounds like the earlier Hemi cars had the standard hinge and latch mechanism. I tried to attach the document, and after downsizing it TWICE (stupid thing has to have the right rotation instead of total pixels), the system went down or something. Fourth time is a charm (I hope).
Name:	1964 Hemi Document (627 x 480).jpg
Mopar 2 Ya!
