Old 10-06-2009, 11:06 AM   #11
SSTHottie1236
SSTHottie1236's Avatar
Default Re: Throttle stops brands
I have a vote for each--#1 Stop and TS-6. Had a TS-6 on my car and was more consistent with an inline stop. Took the TS-6 off, put a #1 stop on and those random 11.0 passes seemed to disappear. On the other hand, my dad still has his TS-6 and the car repeats and everything. So it just kinda depends, I've heard good and bad about the TS-6 but nothing bad ever on the #1 Stop. Biggest issue we've had is clearancing the scoop for the higher carb and throttle linkage. Test test test EVERYTHING before you go to the track for clearance. I've heard of multiple stuck throttles, over-clearancing is and even better insurance policy, remember that scoops can be moved by the air going down the track.
Kelli
1236 S/ST
1836 S/G
Kelli
1236 S/ST
1836 S/G
SSTHottie1236 is offline   Reply With Quote
Old 10-06-2009, 01:04 PM   #12
GaryGoFast
Talking Re: Throttle stops brands
As long as its undercarb style, they all work, I have dedenbear 4500 blade style with a primary kit , air on & air off. Absolutely repeatable.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 10-06-2009, 06:46 PM   #13
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
on secound thought, keep your old stop. i don't want u chaseing me around the pits with some decent stuff, btw, how do u hook up a throttle stop to that amish buggie, one or two mules? mr. yoder....
Old 10-06-2009, 06:52 PM   #14
S/C 302A
S/C 302A's Avatar
#1 Stop all the way. They also have awesome customer service. I had a ts-6, but at the time i had a smaller engine and wasn't real consistant. RPM always krept up on the stop w/ the ts-6. #1 Stop fixed all that and works great on my 565 also. #1 is 1 5/8" thick.
Dave Livesey
2007 Midwest Super Comp Series Champ
S/C 302A is offline   Reply With Quote
Old 10-07-2009, 06:13 AM   #15
Robbie Welch
Liked 262 Times in 124 Posts
Thanks for all the replys. Leaning towards the #1 stop (just hear alot of good about it ) I have to check the hood clearance and the leakage clearance (Thanks Kelli). Keith every one knows you hook it to the lead mule. Thanks again Robbie
