#1 | |
Don't believe it can be done cheap with my car, i believe my index would be 12.10 and im most likely in the 12.40-12.50 range id need more power to get to the index but im kinda running out of bolt-on's for this car and i don't know if any cam's on the market will meet the stock elim specs but cams are also expensive for this car too =P i need to get her weighed but 12.10 index for my car is a stretch w/ out more power (mods) or less weight. bone stock this car ran like 13.8-13.9.. its all good i just wanted to go out and have some fun we'll see what happens. ![]() Last edited by Tweaker; 09-28-2009 at 11:37 AM. |
Liked 4 Times in 2 Posts
Lift is the only thing checked on the cam in stock. If you run pure stock they will check lift, duration, and overlap.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
#3 | |
so lift has to remain stock lift in stock elim? i dont think their are any aftermarket cam's out for my car that remain the stock lift .. Intake Theoretical valve lift @ 0 lash -11.166 mm (0.439 in) Exhaust Theoretical valve lift @ 0 lash -11.066 mm (0.436 in) im seeing aftermarket cams with lifts of .492, .470 .480.. bummer man stock elim class is tough :P Last edited by Tweaker; 09-28-2009 at 12:03 PM. |
#4 | |
Banned
Liked 235 Times in 110 Posts
Liked 174 Times in 39 Posts
It sounds like your car may be close to being legal for Pure Stock. D/PS has an index of 13.10 and your car would have to weigh 3470 lbs according to the NHRA HP rating of 300.
Liked 69 Times in 30 Posts
Tweaker, don't get discouraged, find someone running the class you want to run and ask questions, my daughter got her 2007 Mustang to run 12:25 with minimum ( legal)work, headers from Roush, 4:10 posi, Drive shaft safety hoop, 15"x 9" Bogart wheels, 9" slicks, reprogram computer(You need someone who knows how to set it up) and removal of excess weight. You must follow IHRA guide but I know once you have the right information your car will run properly. Good luck
#7 | |
im going to Private msg u! |
#8 | |
you know what that may be where i belong i'll call ihra folks perhaps they'll let me run in it even though i have the louvers and grille i mean that is pretty lame if i cant because of that and my control arms are non-adjustable streetable steeda control arms nothing crazy or fancy besides that it sounds like i would be pure stock i mean my cold air intake is nothing crazy either its just a C&L plastic elbow w/ a K&N air filter on it on it. thanks ill look into it. Can you run ET Fronts and ET streets in Pure Stock though? omfg, another bullet in my journey... i read in the rule book it talks about only factory tint on windows in pure stock, wtf I live in florida. I have 15% tint on my side windows and rear window.. these rules are RETARDED. They need to be updated from the 1960's and update to 2009. Last edited by Tweaker; 09-29-2009 at 09:05 AM. |
#9 | |
Banned
