Old 09-16-2009, 07:03 PM   #1
Robert Pare Racing
Robert Pare Racing's Avatar
Liked 2 Times in 1 Post
Default Re: Hooker #2241, BBC in G-body
you should not have any trouble. I have tons of plug room. Starter has room to come out..The only thing thats weird is the tube that wraps the steering shaft..make sure the brake lines are at a safe distance. Raised ports on mine as well.
Rapare-Racing.com
Robert Pare Racing is offline   Reply With Quote
Old 09-16-2009, 11:56 PM   #2
Ken Haase
Robert,thanks for the reply. I'm pretty used to the #7 tube over the steering with my Stahl's for the small block. Those two bolts are kind of a pisser. I guess I'll give the Hooker's a try. Thank's again.
BTW, what springs did you use in the front?
Ken Haase is offline   Reply With Quote
