#1 | |
Liked 482 Times in 159 Posts
#2 | |
So far I am happy with them. The chambers seem to have more of a "point" between the valves than others (the inside point if you think of it as being heart-shaped), which required a little surgery on my pistons. Another friend who used the same heads just dremeled out the combustion chambers, but I figured my pistons were old and the heads were new. In retrospect I would have probably cut on the heads instead. I previously ran iron LS7 heads and a smaller cam (0.660" lift), everything else the same. The older combination ran a best of 6.08 in the 1/8 mile, typically 6.15-6.20. With the head and cam change it is running 5.98-6.00 in the same conditions the old motor ran 6.20 or so. My only gripe with Patriot was in getting my order straight (I added some parts to the order and they didn't catch them in the first shipment), otherwise they were great to deal with. I got the equivalent of their "0.800 lift" heads, which come with 2.300 intake valves despite the website indicating 2.250. They were willing to work with me on a custom package, as I didn't want the springs (using a near-new set I had), and cutting for my bigger springs. They had great prices on the other components like ARP head bolts & chrome-moly pushrods. Keep in mind that they require longer pushrods and head bolts/studs (which their website should mention but doesn't). Regards,
Michael Pliska 643 S/G |
Ok, thanks for the feedback. Good to know about the pushrods and head bolts up front. Their heads also have a raised exhaust port I believe,which I think is not really prominently mentionned in some of the descriptions.
Yup, they are 0.400" raised, which was a pain for me as I had just built a set of headers using both stock LS6 heads and angle-milled L88 heads to mock up for. I eyeballed it for fitting raised-port heads, but ended up having to do some surgery to get them to work. Glad I hadn't had the headers coated yet!
Liked 192 Times in 83 Posts
I'm going with the 454R and a decent 1050 on this one..... ran that set up on my 472 and it was great..... 1050 was almost out of the box too.......
#6 | |
Thanks,
I am running a 468" with port matched GM aluminum heads, .712/.712 cam around 274/278 duration. Goes 6 flat @ 3000#. Using the Edelbrock 454R out of the box, Holley 9375 1050 out of the box with a little more jet. Decided on the 9375 because it is annular discharge, supposed to work better than the 8896 with a stop. Have been very satisfied with what I use, but haven't really tried anything else. Good luck.
