Re: Wheel alignment changing...
I tack weld the washers on the control arm bolts after doing the alignment on a F body. .....The camber will sometimes move after a few big wheelstands if you don't tack them. ......Usually if the steering wheell goes off center, it's usually because the camber changed. ........Adger is absolutly correct about securing the coupler at the rack, I've seen a lot of them loose,not only on F bodies either. ...........Tom
