Old 07-10-2009, 06:29 AM   #11
keith ohanesian
Default Re: ss/as-cs
Hood scoops in as, bs,cs the top of the opening can be no than 5 inches from the hood. as uses an 850 while bs and cs uses a 750. as can use a splayed valve or wedge and in bs you can use a canted valve. cs you can only use a iron head without moving the valves. Wedge only....
As For the trans, you can use any trans in any car. Sticks carry more weight..
No prep is king
keith ohanesian is offline   Reply With Quote
Old 07-11-2009, 12:36 PM   #12
Whalen3186
Liked 109 Times in 32 Posts
Thanks for the info guys, I was just curious.
Whalen3186 is offline   Reply With Quote
