Mine was a stock "109" ( casting number) block. The Buick GSCA (Grand Sport Club of America), has its own events and its own classes for all Buicks not only Turbo Regals. The class I was running the car in is TSM ( Turbo Street Modified) and the rules for this class states you must use the stock 109 block. I never had any problems with the bottom end. I did all the trick stuff to reinforce the bottom end , all the oiling tricks, gridle, steel main caps, after market crank, rods and pistons. My biggest problems was in the head gasket world. The stock block has only 8 head bolts and throwing 24 pounds of boost at it head gaskets just don't hang in there. Of all the gasket I tried the Cometic's held up the best.. The Stage blocks have 12 head bolts. Big help there...But for Stock Eliminator a stock 109 block would have to be used.. For a ton of info on these cars there is three real good websites to check out.
1) Turbobuick.com = mostly race oriented 2) Turbobuicks.com= street and mild race oriented 3) T6P.com= mostly race oriented Last edited by GTO/GN; 06-11-2009 at 06:14 AM. |
As someone who has ran turbo cars for a while. Most of the inconsistency is builder installed. My cars were as consistent as N/A cars were. But once in a long while they would throw a faster run at you. I believe due to traction issues past the 60' mark.
The car almost always did its job it was the nut behind the wheel that was broken.
Art Leong 2095 SS |
