Old 06-04-2009, 12:27 PM   #8
OLDGOAT
OLDGOAT's Avatar
Default Re: Cal-Tracs Equipped Car "bucking" on launch
Originally Posted by Chad E532 View Post
I am having some problems dialing in my car now that I have installed the Cal Tracs mono leaf springs and bar setup. The car launches and then as soon as the front end is up on the stops the car seems to rock or buck front to rear 2-3 times before straightening out. We have tried the upper and lower holes and also played with shock settings. I went to a longer travel rear shock thinking I was running out of travel but that does not seem to be the case. I have been able to minimize the action but it does not go away completely. Right now I am running 3 clicks on the rear QA1 shocks (single adjust) with the Cal Tracs in the bottom hole with 1/4 turn of preload each side with driver in car.
The front end has the AFCO bushings, Moroso trick springs, and Cal Tracs 90/10s giving me 4.5" of front end travel. I am running 30x9 Goodyear radials and tried 20 psi and 18 psi with 18 giving me a slightly better 60' but still rocking.
My father also recently put the mono leafs and Cal Tracs on his car and is seeing similar bucking but not to the level that I am.
Thanks in advance for any help you can provide.
Chad
Can you get 5-6" ? That is what was suggested for my car.
OLDGOAT
OLDGOAT is offline   Reply With Quote
