Old 05-30-2009, 01:47 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Motor Home Towing
the thing that will help that unit is a trans cooler ,it may have a factory one on it but, put the biggest one you can fit on it and by pass the radiator you don t need the engine temp to build any heat,unless you towing in sub zero temps you dont need it,you should be ok,amd like mentioned trans temp gauge is key gmonde
