Old 05-29-2009, 05:40 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: PCV, advantage or not?
...and how about on a stocker. i don't know about NHRA, but in IHRA we can not run header evac, is there anyway of hooking up the carburator metering block tube that creates vacuum throughout the rpm range to the pcv to create vacuum even at WOT.
Ian
Ian Hill is offline   Reply With Quote
Old 05-29-2009, 02:38 PM   #2
trmnatr
Ian
Sorry about that, my question wasnt about stocker(s). You guys have some tuff challanges in Stock
trmnatr is offline   Reply With Quote
Old 05-29-2009, 06:52 PM   #3
Bub Whitaker
Ian
All you can do on stockers is intake vacume. If your ring seal is real good than you can use brake booster valves that seal when vacume diminishes and it will maintain nicely.. If ring seal is so so, use PCV valves as they don't seal as well and won't build as much pressure. The main thing here is you don't want any pressure in the crankcase as it will unload the rings and you will loose power, or blow oil out of every orfice that ain't up to the task. which leads me to another important step that you have to pay attention to... You can't have any leaks, you cant build vacumn in the crankcase if it don't seal!!! Test for leaks by slightly pressurizing the crankcase and listen, squirt with soapy water and seal them all up...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 05-29-2009, 08:44 PM   #4
James Perrone
Liked 1,861 Times in 434 Posts
Talking Re: PCV, advantage or not?
Bub
SHHHH!
No more Top Secret Stuff
james perrone 1290 STK
Old 05-29-2009, 09:58 PM   #5
Bub Whitaker
Originally Posted by James Perrone View Post
Bub
SHHHH!
Sorry,,, erase erace erace, delete
Bub Whitaker
Old 05-31-2009, 06:18 PM   #6
Mark Callanan
Liked 64 Times in 14 Posts
Bub if you give up any more secrets I am going to have to visit our family in Sanford...
Lol I hope you are well and so is your family....
mark
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
