Old 05-07-2009, 01:14 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default Re: No HP on the Sorenson combo?
John Kelley Re: No HP on the Sorenson combo?
Originally Posted by George Fitzpatrick
So according to the rule book p48 (weighing of vehicle/fuel check) Fred Henson should have been disqualified from the event. And the run should not have counted. Unless I’m reading it wrong.
Perhaps at the race at Belle Rose being a first round loser he was waved past the scales.I've seen that a lot...
Both good points!! I dont know the answer. Perhaps this should be a change for the future. All participants must scale and pass fuel, win or lose in eliminations, if all runs are going to count towards AHFS? I'm just guessing why one may have got hit and the other did'nt!
Does anyone know if the 427/425 got hit for sure or not
junior barns is offline   Reply With Quote
Old 05-07-2009, 02:00 PM   #2
John Kelley
Red face Re: No HP on the Sorenson combo?
Perhaps this should be a change for the future. All participants must scale and pass fuel, win or lose in eliminations, if all runs are going to count towards AHFS? I'm just guessing why one may have got hit and the other didn't!
It would be great if they did ! But I think it's a time factor deal...70+ cars in Stock at Belle Rose would have taken over an hour to weigh all of them. Plus a bunch more in SS & Comp....
Maybe they need more than one scale...but there will always be a diffrence in scales. Not an easy solution !
John Kelley is offline   Reply With Quote
Old 05-07-2009, 02:14 PM   #3
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Here in Div 1 we almost allways have over 70 cars and we all go over the scales.And a ton of SS and comp. cars and alcohol and others.
Seems the division guys are either getting lax or Glendora sickness setting in.
I think all the fast guys should just start running full out and shedding weight between the stripe and the scales.The first one tossed or given HP should retain a shylock lawyer and rolll the dice.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 05-07-2009, 02:35 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: No HP on the Sorenson combo?
I would say that if a racer looses an elimination round and he is not directed to go to the scales then he is not required to do so.
Jim Cimarolli is offline   Reply With Quote
Old 05-07-2009, 02:43 PM   #5
George Fitzpatrick
George Fitzpatrick's Avatar
Liked 94 Times in 24 Posts
If it’s going to cost over 100LBS he should. That one run By Fred Made the Ebodys with a Hemi Extinct.
George Fitzpatrick 426 HEMI STK, SS
George Fitzpatrick is offline   Reply With Quote
Old 05-07-2009, 02:50 PM   #6
George Fitzpatrick
By the way Sorenson thought it, out and saved a lot racers weight.
Old 05-07-2009, 03:00 PM   #7
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
I agree with you Jim, but if it is a run of 1.40 or more under and it will affect your HP rating then it should be mandatory to weigh and tear down regardless of whether you win or lose. (although not in the rule book) I think this whole thread has gotten off the topic of what really happened. I don't care if it was windy, I don't care if the scales were fluctuating, I don't care if your weather station said you were going to slow down, if you ran 1.391 under why would you take the chance of possibly going faster. I was not there but if water was indeed drained from the raditor or anyother item was removed from the car that was in the car during the run should have remained in the car when scaled (including the water). So tell me, does this set a rule of thumb for anyone that goes 1.40 under, take what you can out of the car (drain the water, drain the oil, drain the trans fluid, leave your jacket, helmet and pants with the car behind you) so that you are light and the run doesn't count? I would like to see someone get that by Bruce or Travis here in D3 ...
That is the biggest problem I have with NHRA is the inconsistancy across divisions.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 05-07-2009, 03:06 PM   #8
Jim Cimarolli
I see your point Chuck.
Old 05-07-2009, 03:23 PM   #9
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: No HP on the Sorenson combo?
.....If a man's mistakes determine what he was, then what he does about those mistakes determine what he is .......... If Sorenson's get no HP, then the right thing for NHRA to do is tell Fred Henson; we're sorry, we made a mistake, and remove the HP off the Hemi A body. Especially because the circumstances are so similar. If not, then Sorenson's get HP too. It's black and white. The only thing missing here is a little Gray Matter. JB
Jim Bailey is offline   Reply With Quote
Old 05-07-2009, 06:13 PM   #10
OLD GUY
Liked 9 Times in 2 Posts
Chuck you are right on the money except I believe this is a Glendora call not a divisional call. The truth of the matter is if you read the AHFS rules it states "1.40 under the sea level index you will get 3.25% HP period. It says nothing about weight, fuel check, or tear down. Sorenson went 1.408 under the sea level index he gets 3.25% HP.end of story. Altering the weight to get the run disqualified is a whole other issue and that deserves a suspension. We have two major problems here. I for one would be very curious to hear Travis's interpretation of this situation. Dan Fletcher quoted it pretty well. "ur 1.40 under ur hit"
I sure hope you aren't talking about Bruce Bachelder because I have been told that he is the guy who won't make the decision or return phone calls.
Dave Schmitz
OLD GUY is offline   Reply With Quote
