Old 05-04-2009, 05:13 PM   #1
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: Fred Henson vs. Sorenson
BOISE, Idaho - Order after 3 rounds of qualifying in Stock Eliminator at the NHRA Lucas Oil Drag Racing Series, Northwest Division, 39th Annual NAPA Auto Parts Ignitor event, presented by Dan Wiebold Ford, at Firebird Raceway:
Weather conditions: air temperature 69 degrees, relative humidity 27 percent, barometer 27.28 inches, adjusted altitude 3,879 feet, track temperature 93 degrees.
Psn--Num--Class-Driver, Home Town, Machine-----------------ET---Index---(+/-)
1 633 B/SA Hal Sorensen, Vancouver WA, '69 Camaro 10.142 11.93 -1.788
2 6471 K/SA Bill Edgeworth, Tacoma WA, '77 Firebird 11.658 13.38 -1.722
3 7980 F/SA Steve Wann, Modesto CA, '73 Dart 11.000 12.55 -1.550
4 6149 B/SA Wesley Libby, Mead WA, '71 Challenger 10.418 11.93 -1.512
5 6300 C/SA Glenn Person, Regina SK, '70 Challenger 10.590 12.09 -1.500
And what about this?Is this the missing 18 minutes of tape from the Nixon White House??????????
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 05-04-2009, 05:22 PM   #2
junior barns
Liked 20 Times in 14 Posts
did'nt make weight!!!!!!!!!!!!!!!!
junior barns is offline   Reply With Quote
Old 05-04-2009, 05:50 PM   #3
Ed Fernandez
Why??????????????????????????????????????????????? ??????????????????????????????????
Water condition?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 05-04-2009, 09:45 PM   #4
herbjr
Liked 83 Times in 32 Posts
You should ask one A/SA racer from NC what he thinks about Hensons run. Total BS.
herbjr is offline   Reply With Quote
Old 05-04-2009, 09:47 PM   #5
junior barns
Water condition?
who cares! if he done something illegal then he should be suspended!! if he crossed scale and did not make weight the run does not count!!
Old 05-04-2009, 09:59 PM   #6
Ed Fernandez
Water condition?
If he didn't make weight due to the fact that the radiator was emptied don't you think that's a rule infraction that needs to be addressed.
All that's required is a simple yes or no.Not a lawyer answer.
Why didn't the final qualifying sheet show the DQ for the final run?Answer anyone?
Ed
Former NHRA #1945
Former IHRA #1945
T/SA
Old 05-04-2009, 09:59 PM   #7
bill dedman
Liked 6 Times in 4 Posts
Junior said: "if he done (sic) something illegal then he should be suspended!! If he crossed scale and did not make weight the run does not count!!"
That's pretty simple logic...
Bill
bill dedman is offline   Reply With Quote
Old 05-04-2009, 10:25 PM   #8
OLD GUY
Liked 9 Times in 2 Posts
Biill,
AHFS rules don't say anything about weight. They say you go 1.40 under the sea level index you get 3.25% HP period. If you are dumb enough to run your car light and go 1.40 under then you probably deserve a bigger hit than that. Hensen didn't weigh, no fuel check, and no tear down to verify legal motor. He got 15 HP the following Monday. Sorenson should get the same and a vacation for altering weight after the run before the scales. They are not novice racers and know better than to do what they did.
Dave Schmitz
OLD GUY is offline   Reply With Quote
