View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 04-26-2009, 12:13 AM   #7
trmnatr
Default Re: .031" Dykes or .043" Rings ?
Originally Posted by Jim Cimarolli View Post
I have tried just about everything out there, and for my money I choose the 5/64 back-cut top and second ring with the low tension oil ring by Tri-City Competition Service, for a stocker motor that is with the 5/64 ring lands. Call Greg Luneack @ 760-630-9094 He will fix you up, and he is a great guy to deal with.
Jim,
Thats the kit with the gas ported spacers and thin narrow rings below the spacer , all in the 5/64" groove ?
Anyways the engine im doing is not a stocker so i can go with any ring i wish. You use the .8mm or 1.2mm ring with the spacers ?
The 3 rings i listed were what i thought about going with
Hey, maybe the 5/64" groove with gas ported spacer will knock some weight out ?????????
Thanks for the contact info
trmnatr is offline   Reply With Quote
