Just wondering if anyone has had this problem. I have broken 2 SW torque arm mounts. The large bracket that bolts to your 12 bolt. The first one I caught before anything happened. The second one broke last night and took the trans with it when the rear end rolled up. Anyone had this happen to them? any suggestions on what went wrong?
Liked 3 Times in 1 Post
Ricky, i am not sure when you got yours but the ones they are building now are Heavy duty compared to the earlier ones they built. I cracked one of the earlier ones several years ago but i have not heard of this since they changed to the heavier ones!
Woodro Josey 2002 STK |
Liked 10 Times in 3 Posts
we have broken 3 in the past 3 years. The last one was at the Dutch this past fall after only 16 runs (car is 305 stick camaro). We have always been treated very well by S&W when we call after we have had problems, but that was the 3rd strike.
We how have a PeteZ (Z torque arm) setup (ATE) that we will be testing as soon as our engine is done. Rich Aman 1631 G/S
Rich Aman 1631 STK |
Liked 652 Times in 184 Posts
I've been 9.70's and 1.31 60' on a Burkhart chassis torque arm with a stick, he makes a very nice piece. As to why yours broke hard to say ,but the bolts on the bracket to the rearend housing seem to want to back out alot I'm constantly checking mine and have broke one like you because of it. That may have not been your problem ,but its very common on these cars. Hope that helps.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
![]() Ricky: I thought I was the only one! The torque arm mount was in the roller when I bought it. It looked a little light but I didn't know a thing about these cars and assumed the builder did. My nice new MW driveshaft was MIA along with other bits and pieces. Hopefully the mount I built will sty in one piece. Cam Cam Last edited by Cam; 04-18-2009 at 11:33 PM. |
Liked 216 Times in 77 Posts
I would have to say that the one pictured here that broke must be one of the older ones. Reason I say that is because I just bought one over the winter and the bracket on the rear looks to be alot heavier meterial than that one. I will say the one you made if that is it on the bottom is a nice looking piece.
Liked 26 Times in 13 Posts
Might look good but if the bolt threads aren't long enough to engage the nylon in the nylock nuts then your gonna be scattering stuff all over the track. Another 1/4 inch on those bolts is probably worth the investment.
Bill Harris ex 2172 STK ex 2272 S/S |
#8 | |
This is just a mock up, check out he pinion nut. There is still 4 feet of snow in my yard. I'm not going anywhere soon. Cam |
#9 | |
Wow, I didn't notice your location.. not just BC but NORTHERN BC... I'll bet you aren't going anywhere soon... maybe August....!!!!
![]() BTW, I envy you, what a friggin' GORGEOUS area.
