Old 04-15-2009, 06:04 AM   #1
rodrocket
Default Lamb Struts - Wheel Bearing Help
greetings All
can anybody help me with some info in relation to the correct bearing & seal to run on my car
it has Lamb struts ( Anglia ) & i have just purchased a new set of front wheels ( Alumastar 788-15000 ) Anglia
the issue i have is Lamb list "SPECIAL" bearings for this application
the bearings that come with the new wheels are as follows
Inner Race: 4T - 07204 - NTN
Inner Bearing: 07097-544
Outer Race: 03162 HP
Outer Bearing: 03062
Seal is Timken boxed with the part number of 471795 however the seal is marked "NOK AD7127E"
what i need to know is, Do i need to buy
A: The Lamb "Special" set
B: the 07098 Bearing
C: the C-R (Chicago Rawhide) 12565 SEAL
D: Use what i have been supplied with the wheels
the above two part numbers i have found through different forums
regards
rod
rodrocket is offline   Reply With Quote
Old 04-18-2009, 08:07 PM   #2
rodrocket
Default Re: Lamb Struts - Wheel Bearing Help
i would of thought that somebody here would be running the Lamb struts with an Anglia spindle in here ???
regards
rod
Old 04-18-2009, 10:22 PM   #3
trmnatr
i wish i could help you but im sorry i dont know
Good Luck and hope you get what your looking for
trmnatr is offline   Reply With Quote
Old 04-19-2009, 05:43 AM   #4
Mark Callanan
Liked 64 Times in 14 Posts
Originally Posted by rodrocket View Post
greetings All
regards
rod
Rod
Call Roger Lamb on Monday he will have all your answeres
(909) 985-1901
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
