That's a good one.All that I can think of may be a sticky needle or plunger on your dial indicator.And make sure that the stem of the indicator is on the same angle as the valve stem.I have had the stem of the indicator ride into the "dish" of the retainer and give you bad readings.Good luck. You will figure it out!
