Old 03-14-2009, 12:02 PM   #1
Ken Haase
Default Re: QA1 front coil-over suspension
Thanks for the reply Vic. I've had the coil-overs on the car for a couple of years but have only been out once each year. It sits a little higher in the front than I like, even with the spring seats at the lowest possible setting. I'm switching from a SBC to a BBC so the added weight should drop the nose.
One other thing. I tried turning the adjuster knob recently, but it acted like it was 'frozen'. I didn't want to force it and break something. Shouldn't it turn relatively easily and are there some do's and don't's? Such as jacked up with the weight off? As I recall, the only instructions that came with them, dealt with installation only. Anyone got a phone # or website?
Thanks again
Ken Haase is offline   Reply With Quote
Old 03-14-2009, 04:46 PM   #2
SlickVic
SlickVic's Avatar
Not to be smart, but are you turning it the right direction? sometimes they do get a little stuck depends on how long they have been in that position, and they definitely get harder to turn the tighter you make the valving. I still wouldn't force it though.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
Old 03-16-2009, 04:58 AM   #3
THE LEGEND
I have the QA1 coil over set up on my 10.90 car. They work great. The only problem I've had is shocks went to leaking and had to be replaced. I got 2 seasons out of them. I figured I would've got more than that.
Chip
THE LEGEND is offline   Reply With Quote
