Old 03-08-2009, 01:53 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: 12V Battery Reccomendations
Originally Posted by Shawn Blair View Post
I have two Optima red tops in my car that are 8 years old and they still work great! No alt. charge between rounds when there's time. Also if you have a Optima that has went dead on you and you can't get it to take a good charge, take a standard wet cell battery and run jumper cables from it to the Optima and hook the charger to the wet cell battery. So basically your just charging through the first battery to the Optima. I've seen this bring back a few so don't get rid of it until you try this first,you may be surprised! Shawn
Shawn's right on the charging across another battery. ..I was told to do this by our Interstate battery rep. .....I tried it on a red top that had repeated gone quickly dead. .....It took about two days of charging an a very low rate,but the battery came back and I've been using it for 2 years in a street car that sometimes gos for months without starting. ...Works every time........Tom
